Custom Web Interface Update
Hello,
i programmiing a custum web Interface and i update my msc Controller about mosaic designer 2 tool.
Is there a faster way to update the Web Server ?
Or i can work live on the webserver and make a update ?
thanks for answers
Joachim
  • Are you just updating your CSS/HTML? or are you updating your javascript/LUA as well?
    For CSS/HTML I usually just upload my project with a web GUI in place and use google chrome developer tools to modify then copy and paste my changes into the document I was originally using.
    Disclaimer: The next tip should be used cautiously.
    Every time you open a designer file it creates a temp folder with the current web GUI and all project related files in it.
    I often have my sublime text editor linked to the web interface folder that is found here so I can make all of the changes I want and click upload in designer to see them. This is my preferred method for changing JavaScript and bulk editing CSS/HTML. Its still not "real time" but it saves the step of deleting the old file from designer and finding the current file again.
  • Very fast.
    Thank you for your solution.
    I update css thml javascript with my editor link to the web interface folder. Thats it.
