I would like to add our company logo and the picture of the project (facade illumination) to the MSC web interface Home page without changing anything else. Can this be done?
Kind regards,
Andres
Kind regards,
Andres
Hey Andres,
did you check out the Custom Web Interface already? :-)
It's like programming a HTML Website ;-)
To add a custom web page, or set of pages, to the web interface on a Controller, go to Project Mode, Web Interface Tab, Custom Web Interface and select Edit...
This will open a dialog that shows the files that currently make up your custom web interface.
Cheers,
Markus
This page of the manual explains how you can do some simple re branding of the web interface which I believe you are after.
https://www.etcconnect.com/webdocs/controls/mosaicdesigner/welcome.htm#help/reference/project/web%20interface.htm#Custom2
Anything further than this will require a full custom web interface.
Tom
I will check once I get to the controller, thanks.
Was hoping there was a simple "upload image here" button, that I was missing :) And I think I got the thing I was looking for from Tom in a reply below.
Thank you.
