Air Temperature sensor
Has anyone hooked hooked up an air-temperature sensor to a MRIO to fire triggers and overrides in Mosaic?
I have an outdoor installation that i need to trigger different start-up sequences based on ambient temperature.
Any advice on where to start with this would be appreciated.
  • Hi Nick,
    The papouch TM is  a serial thermometer, https://en.papouch.com/tm-rs232-thermometer-p1887/ that I've used for this before and there is a convenient integration module for this in the Designer library.
    Please note you'll need to have an external PSU, the MRIO don't provide power on the serial connection.
    Alternatively, you could consider integration via the Accuweather integration module, in that case you would need internet access, but you wouldn't need to connect up additional hardware.
