Hi! I'm looking to add a slider on an MTPC to control the screen brightness. How can I set the slider to never go below 5% brightness so it won't turn completely off?
Hey there! If you want to add a slider to control screen brightness on your MTPC (I assume you mean a Mobile Touch PC), you can set a minimum value of 5% brightness. This way, the slider won't allow the brightness to go below that level, ensuring it never turns completely off.
revida marcos
