GTFS RT data as triggers
Hi there,
I have 3 light installation in bus terminals along a single bus line. I'd now like to make those installations respond to buses arriving and departing the stations. The transit system uses GTFS RT data ("General Transit Feed Specifications Real Time") to track the buses which I could tap into.
Did anyone ever try to use GTFS RT data or similar and Lua script to create triggers in Mosaic Designer?
Thanks for your help in advance!
Erwin
