Turning a DMX Record file into a preset
I know DMX Record was created to capture clips for playback on Mosaic timelines. Is there a way to capture a static look into a Mosaic preset without having to manually enter DMX values for 8 universes of fixtures?
We were programming the installation with an Eos console and capturing with DMX Record for playback on an MSCX. Discovered I can't tweak anything in Designer because there was no way (that I currently know of) to add a fixture patch to the clip. If there is truly no way to do that, it would be a great feature to add in the future.
