New feature - patch info tooltips in setup screen is great except that the DMX values are off by one. i.e. fixture patched to channel 1 shows to be patched to channel 0, etc.
Dall,
The issue you encountered is a software defect. This has now been logged, and we will work to correct this as soon as possible. We will be releasing a new version in the next couple weeks. Unfortunately, I don't think we will be able to work this into 1.9.2 since it is currently in final test, but we will correct this in the version that follows.
Thanks for bring this issue to our attention
