paradgim fixture profile request
hello
we need a profile for the MIRO CUBE WNC. this is a three color white fixture with no intensity chanel.
  • The simplest way to get this profile is to contact ETC technical service or email the necessary information to support@etcconnect.com. In order to build the profile we will need the following information.
    • Fixture Type
    • DMX mode (8-bit or 16-bit)
    • Fixture mode (If supported)
    • Date needed
    • The DMX personality of the fixture(link to the manual is best)
    I looked up this fixture quickly and it appears to be a single channel fixture. Color temperature seems to be set on the rear panel and intensity is the only control channel. IF this is the case you can simply patch them as standard 8-bit or16-bit dimmers and they will work correctly. You can rename them in the Property Editor of LightDesigner to keep track of them within the configuration.
    If you still need a profile created, please send in the above information and we can get one created and sent to you.
  • Dear Sir or Madam,
    I would like to request the profile to the City Theatrical AutoYoke fixture for the LightDesigner.
    ●The PDF Link: http://www.citytheatrical.com/pdfs/AutoYoke_Manual1-6.pdf
    Regards,
    • Fixture Type
    • Date needed
