i am in a facility that has a Sensor CEM+ and a Unison CMEi unit. There are net ports all over. I have in inventory some NET3 ACN Gateways I have switched over to the NET2 option. i then use the NET2 version 4.1 software I can check my software versions and identify the sensor rack, unison processor and the gateway. I can even bind the gateway to where I can see it online using the NET2 configuration software. However the problem arises when I attempt to send the configuration to the node.... I end up getting an IP memory error. Anyone have any ideas on how to fix this?
