I am working on a job that has two spaces each identical, both have two touchscreens a piece. The CD configuration has a splash screen with an entry keypad and three levels of pass codes where each codes, when entered, is directed to it's own start page in LD. What I am wondering is if there is a way to have the pass codes correspond to visibility groups so that when each code is entered the same start page appears but different levels of buttons are seen.
Is this not possible? Should I stick with the system that isn't broken?
