My client has a an ETC Unison DR12, with CMd Control Module.....where none of the channels are dimming.
Observed:
- had Low Voltage Error, even though DMM shows the 220 single phase supply is running 135VAC per leg.   So, it's definitely not getting a low voltage.
- I set the front LCD configs to 0V and the error went away. Although, I don't want to leave it configured like that.
- I also checked all the configs for each of the 24 Circuits and DMX settings.  Everything is configured 1 to 1, and in straight sequential order, and to "Incandescent".
- Likewise, I've been testing with a Leprecon LP-1524 Lighting Desk.
- But, in order to eliminate the LP-1524 as a possible issue, I brought in a Leviton MC 7008 (as seen here:  http://www.fullcompass.com/prod/175129-Leviton-MC-7008 ).  And, it is behaving exactly the same.  So, since the Leviton doesn't have any funny programming abilities, that eliminates any possibility that the LP=1524 had channels programmed to only do 0%/100% only.
Anyone have any idea what the issue is?
- Rob
