Is there any way to setup the Sensor3 TPSR app to use with sensor dimmers and where to get the QR codes.
Alex
Alex
Hi Alex.
You can use the App with any Senor Module, but the app was specifically created for ThruPower Module so you can easily switch between Dimming/Constant On and Relay Mode as you re-hang a show in a hybrid space.
You can order the standard QR Codes (Circuits 1-366) directly from the ETC Store. If you need a custom set we can do that too. https://shop.etcconnect.com/sensor3-tpsr-app-qr-label/
The requirements to use the TPSR is a CEM3 processor on firmware version 1.6 or higher, you will need a Wifi Access Point in your system, and have to download the free Sensor3 TPSR app on Android or iPhone.
For additional info where all of the above can be found please RTM: https://www.etcconnect.com/WorkArea/DownloadAsset.aspx?id=10737492559
TPSR Proudct Page:
https://www.etcconnect.com/Products/Power-Controls/Racks-and-Panels/Sensor3/TPSR.aspx
I hope this helps. Please let us know how your space turns out if you add the QR Codes.
