Paradigm USB file load/save
My Paradigm suddenly stoped seeing USB drives for file operations.  The SD reader still works.  This happened once before and then suddenly started working again.  I checked with 3 different USB drives which I've successfully used in the past.  Software 4.1.0.9.0.1077  I find USB drives more convenient than SD cards so would like to fix/reset whatever this problem is.  Any suggestions?
