Triggering Contact Outputs
Having a complete brain freeze at the moment....
I am trying to setup a series of Macros to fire a sequence of contact outputs on the I/O board across 2 processors (some together, some independently)..... but can't see the means to assign the output contact to engage/disengage as I would do on an input trigger....
Property editor only shows the contact output as an indicator, is this correct?
