I'm looking for the Wattage of the P-CCS assembly - both server and conductor together. Needing to do rack BTU and VA calculations, and I'm not finding that in the latest spec datasheet available F dated 2/2019
Ian Campbell Both products are 12VDC and max of 5amps. I'm pretty sure they are no where near that in actual use. But that would mean W=VA, so 60 watts max per device. So 120 watt in the rack.
1 Watt = 3.41 BTU
120X3.41 = ~410 BTU at Max.
