What is wrong with the above image?
I assume you are pointing to the wrong DMX address being listed.
This is an emulator we created and not using the actual version of the software inside the PACP. It was manually made during the pandemic so we didn’t have to be in front of the physical gear as much. It is very likely just a mistake in the emulator but not in the physical software used.
For those curious the emulator is here.
support.etcconnect.com/.../PACP_User_Interface_Emulation_v4.2.4
