Hi
Recently had a call from a sight that we installed a Paradigm System almost 2 years ago. 2 x DRD12, some heritage stations and a Touch screen. There is no console in the space but we have 2 2port gateways 1 input and 1 output for when they want to do an event where the use moving lights and need a console. For 2 years they never needed to use the gateways. Next week they will have a show where this function will be used for the first time.
Connected a DMX tester to the input but could not control the dimmer channel. Did get output from the output Gateway.
Wen looking at the processor the sACN level is at 100% but Current Level at 0%.
Can control the dimmer level from the Paradigm Touch Screen but the sACN level does not change.
it displays The source as BOOT LOOK
It should display Source:Arch or Source:sACN
Could not find any explanation on Boot look in the manual except for how to clear it.
tried Clear Boot Look only, Clear All Arch Ctrl but no change.
Did a Hard Reset and it started to get sACN signal from the Gateway BUT it still displays Source : BOOT LOOK
we also checked Power on Behavior was set as Action : None
P-ACP version is 1.1.0
Any thoughts
What does Boot Look mean?
