When i went this morning to turn on the light the Dimming control module was off and i could not turn on. It looks like the power supply is dead. Any help on wfat i should do next.
Kill power (30 seconds or so) then turn on again.
Then call tech support or your local dealer. If it's time critical then use the factory off-hours message, a tech will call you back withing 15 min!
One or the other should be able to guide you from there. If there is a box of weird stuff from the installation then you might have an 18" jumper cable that bypasses the controller. But call them first!
