Can the Echo Inspire button stations controlling D60 fixtures and DMX relays through a Scene Controller be set up to pile on? Thanks
Hey Indy, I was wondering if you ever found a solution to your question.
If you are asking if DMX will pass-through and HTP with the Inspire stations Echo "Arch" look, (Paradigm "pile on") the answer is yes.
The Echo DMX Scene Controller will pass-through the DMX input to the DMX output and HTP with any active Echo levels.
Hope that helps,
Noah Zimonick
Product Assurance │ ETC, Inc.
