I'm hoping someone can recommend a product that I can use for connecting wires in a DIN Rail Enclosure for an Echo system...
I have previously used WAGOs to connect multiple wires together, i.e. the unison wires and the aux power wires, but I feel like there must be something better than this to use.
I looked at some DIN rail mount terminal blocks, but I have never used them before and and there are so many variations that I'm not sure what is best. I need to be able to have one wire feed three or four other wires.
Any suggestions would be appreciated!
I have used automationdirect.com in the past for small projects. You could do a DIN rail terminals with jumper strips, depending on how much space you have available.
https://www.automationdirect.com/adc/Shopping/Catalog/Terminal_Blocks/DINnector_DIN-Rail_Terminal_Blocks
