Hi all, downloaded the new Echo Touch Offline Programmer.
Been fooling around with it for a bit, and have some questions:
1. It seems in setup, that the Echo Touch Controller can only be assigned to a single Space, is that correct? So that means any zones patched to it are all in the same space right?
2. building off the last question, if I want to configure 2 different spaces, that were controlled by their own presets, I would need a second Echo Touch setup to be a different space and configure the second one with only the lights I want it to control in that space.
3. And thus to confirm, There is no way to exempt say, Zones 11 thru 20 from being recorded into a preset right?
My goal is to control Some Houselights on Foundry Dimmers on Page 1 Presets 1 thru 4, and then control some zones on stage from Page 2 that won't affect the House Light looks set on Page 1, and then possibly a combined Page 3 for controlling all the zones.
And it seems so far that's not possible, since Echo Touch will control all the zones in every preset.
