Hello, I just installed the echo touch controller a the church. The system has a combination of echo dimmers and relays as well as Colorsource PARs The church audience lighting is controlled by the capital dimmers, and all of the RGB lighting are on echo relays for power
The presets and faders work just fine on the Echo Touch. But I see in the manual I can only create sequences for DMX zones only. Are there any plans to upgrade the software to execute sequences that include echo zones as well as DMX only zones?
The house lights are in echo zones and so are the relays that power the ColorSource PARs. So when I create a sequence and then stop it, all the lights in the room cut off because they are in Echo zones. Is there a way to avoid this?
You might want to take a look at putting your relays in a separate space.You could then have independent preset control of control of your DMX fixtures in one space and your Echo Relays in another.
