I'm looking at a project where I will want to install a Room Controller, and some occupancy sensors to control the lights in 2 Bathrooms.
I plan on commissioning this little system with an Echo Access, so I can control the Level the lights dim to.
I found a 0-10V Driver for the LED Tape we're using, but I'm having a much harder time finding a Line Voltage Dimmer that listens to the 0-10V control from the Room Controller.
Any thoughts on solutions for dimming a 120VAC Load from the Echo Room Controller?
Hi Shadow20X6,
I would like to have someone from our sales team chat with you to see if we can help you with this further. May I ask where you are located so I can direct you to the right person?
Shawn
What is the wattage load of the 120V load
Los Angeles CA, and for the Load, not much, definitely under 600W. As I submitted this, it clicked in my head that i could redesign the system somewhat to use a 4 Room Controller for the 0-10V stuff, and 2 Echo Dimmers for the remainder, so I felt somewhat silly after posting as i realized I didn't need to control the Line Dimming from the Room Controller.
Glad you figured out why solution. The 600w dimmer is the way to go. I wasn’t sure if the load was over that. Should be a nice little system.
