I've still never installed an Echo System, and all of my research is through Data Sheets and the EEB app on Concert, so It's very likely I'm missing something.
On the DMX Scene Controller, there is a tab for adding in Presets that have been recorded into a single Sequence. You can change the Dwell and Fade times, and Looping options on this page.
But my problem is, if I'm currently looking to do something similar through Gen 2 Echo Dimmers, how would I accomplish something similar? I can't seem to find an analogous page for Echo Zones in a space, to build a Sequence.
Are Seqeunces dependent on the devices that are controlling the Presets? Would that mean a Sensor 3 could build a Sequence, but not individual Echo Dimmers?
Hey Shadow,
Only certain Echo products support sequences at this time. Those are the DMX Scene Controller, EchoTouch, and our Panel controllers, like CEM3, E-ACP, and E-PCP. EchoTouch can support four…
Hi Shadow20X6. I think the easiest thing to do if I understand what you are trying to do is just save each Echo Dimmer as a Preset with only that dimmer in it and play that back.
Only certain Echo products support sequences at this time. Those are the DMX Scene Controller, EchoTouch, and our Panel controllers, like CEM3, E-ACP, and E-PCP. EchoTouch can support four sequences, while the other devices can do one each. The Scene Controller is the only device on that list that can be configured from EchoAccess, which is why it's the only one you're seeing with this option. Unfortunately, you're not able to include the Zone Controllers.
If you'd like to chat further, please reach out!
