I am having an issue where the echo system is combiming spaces on its own, I do not have any space combining actions programmed anywhere within the system and some of the spaces that are being combined are not even used, oddly enough it will lock out spaces also. This is seemingly happening at random and I have the system built and connected within the directed parameters.
Hi There. This sounds like it could be either a wiring or a programming issue, but I can't be sure without knowing more about how your system is put together. I would highly recommend calling the factory at 608-831-4116 and asking for tech support. They will have access to your project information and will be able to help you through your problem in real time.
- Dave
