Before I confirm a system change of removing an ERMC8-TC from a system currently installing that has an ETS could work- they need a time clock function in the space. Can E-TS work as the TC?
Correct. The current version of Echo Touch has time clock functionality built into the software. You can only have one time clock per system. So you will want to make sure to use the standard version of ERMC8 (no time clock) (however that is currently on back order). You may want to look at the Foundry Mini Panel as an alternate that uses the same hardware but runs on DMX which the EchoTouch can also generate.
