I have an application where I would like to use an Echo touch controller with the Amigo support as is possible with the color source console. Is this supported by the Echo Touch? Also, is OSC supported on the Echo Touch?
Steve
Steve
There is no Amigo support. Also no OSC, but there is support for UDP Strings.
As Aaron mentioned Amigo is not an option in Echo. It’s really meant as a remote focus option for the color source console so you are not running back and forth to the console as much. Something less common for sure in the architectural world.
But depending on what you are trying to do there is Echo Access a Bluetooth or WiFi based app that can be added to an EchoTouch system. You would need the Echo Access or Echo Expansion bridge with a WAP to get this up and running.
Thank you.
