Hi There,
Is there a document somewhere that lists the fixture profiles in the console? I've done several searches and can't find one.
I have a customer interested in the console and they had asked if I could provide one.
Hi There,
We've done a few updates to this fixture in Library Update 16.1.6, which will be on the website "shortly".
The main changes are:
PS: In the ranges filmstrip each item is labelled for the Color Temp you (should) get from selecting it.
You can then drag the parameter tile 'up' to increase the CT within that range, until one DMX tick below the next one.
Richard
This sounds wonderful thanks.
I can't wait to try it out, hopefully later in the year.
Many thanks for all your hard work.
Alan
