Hi
I have two questions about the simple mode of the console.
If i use the simple mode, and i go in the settings of the console i can find, the "Basic" set. the "Times" set and the "Ind." set.
But i don't understand why in the "Times" set. i have the "Default cue time" also if i can't record a cue. I can record only 4 Playback Memory and doesn't work with the Default cue time.
The second question is, why when i insert the "clear time" (ex... 10'') and i do a manual change, after i raise the Memory's Fader and the first memory take this time?
