Is it possible to edit the tags that are used in the patch screen of the ColorSource 40AV? I have searched and cannot find a way.
Thank You.
Thank You.
Hello,
Currently it is not possible to change the list of available tags. Are you missing a tag that you would like to be added in future versions ?
Regards,
Hello, a lot of -> could be this editable by yourself;oDD
But it's posible to write them directly in that Java file of show..
If you open you find them in patch part downstairs in file:
"patch": {
"devices": [
"channel": 0,
"deviceId": 1,
"dmx": 1,
"footprint": 1,
"invertPan": false,
"invertTilt": false,
"manufacturer": "",
"mode": "",
"model": "Dimmer",
"personalityDcid": "",
"swapPanTilt": false,
"tag1": "Spot",
"tag2": "Courtyard"
And in tag, you can write everything you want but than it's not possible to edit them from console
Simon
