Hello,
Is the Colorsource 3.1 offline version working with Capture MAC (3D simulation) ?
Do we need a particular version of Capture?
And what network settings should be made?
Hello,
Sadly the Mac version of the Offline Editor doesn't support local machine connection to capture. The PC version does.
.....If you have a DMX to Ethernet converter like a Response Mk2 gateway you could use that to connect to a Mac running Capture.
So, since I only have one Mac, what I tried is to run CSoffline PC through Parallels desktop, and Capture Mac simultaneously. Well, oh surprise ... it works. It takes a lot of resources from my Macbook Pro, but it works. So here is an offline solution.
