Renumbering cues. Missing the function that can renumber the cues. Can It be in next SW update ?
Hi Lighttech if you go to Record/Edit then select Cue List
Then select the cue you'd like to renumber and tap the number field at the top:
That will give you an number pad to renumber your cues
I have seen this. But if I add a cue f.x. after 7.0 and named it 7.5 and next cue no is 8.0, I want the function to renumber ALL the cues, so all cues get a new numbers f.x 7.0 , 8.0 and 9.0. So the add´7.5 get number 8.0. The present 8.0 is now 9.0.
I don't think you really want to do that.
Your assistant stage manager might want to bury you in a ditch somewhere if you renumbered all the cues in a show, and asked them to update all their paperwork too...
Oh Yes. I really want to have that function.
