Scroller Calibration on ColorSource Consoles
Hi there!
On the ColorSource family of consoles is there a way to calibrate scroller frames as there is on EOS family? I have a number of Apollo Smart Color scrollers (loaded with the stock R&R string). When patched, it shows the 16 frames under the ALL tab. However not each of the color buttons moves the fixture to a full frame. On EOS, you can calibrate to tell the desk on a per channel basis what the center of the frame is.
Does such a feature exist?
Alternatively, is there way to create color 'palettes' on this desk?
-Mike
  • ColorSource doesn't currently have scroller calibration like in Eos.
    You can record Color Palettes in the second page of Color parameter controls.
    Set the string as needed, then {Record Palette} and tap the chip to record.
    These are per-channel referenced data.
    There are also Focus and Beam palettes of course Slight smile
    Note: If you have {Update Color Chip} instead of a {Record Palette} button, that means you're running a rather old version of console firmware and you'll need to update it to get Palettes.
