Help... editing cues with the ColorSource 40 offline editor, cannot insert a cue in between two other cues. If I have 30 cues, and don't currently have a cue 17 but want to add one, it adds but puts it at the end of the cues instead of in between 16 and 18, so, after cue 31. I am using the offline editor but on my way to the theatre now, totally screwed if I can't fix this. How do you put cues in numerical order?
Hey blake_r when you're creating a cue you can click on the cue number and type in whatever value you'd like:
Likewise when you're editing cues you can renumber in a similar way:
Let us know if that covers your question
That's exactly what I did, but it shows up in the cue list at the end, out of numerical order.
If you save the show and then re-open it does it still appear out of order?
Hi Seth, I closed and reopened it, and when I reopened the file it still showed out of sequence, so I left it to sit for five minutes or so and now the cues are displaying in the correct order... I am hoping this is just a bug in the offline editor with the file displaying properly and that it will be ok on the actual console. Thank you Seth and LowellOlcott.
