I recently had an accident occur and I need to source a new screen for my color source 40, any suggestions on where to find one? I did a typical google search to no avail. Any advice on this would be greatly appreciated.
Assuming you mean the built-in touchscreen, your preferred ETC dealer can sort this out for you.
- You can search for a dealer here: https://www.etcconnect.com/Find-A-Dealer.aspx
The screen flexible PCB "ribbons" and connectors are quite fragile parts, so you may prefer to let an ETC service provider do the repair if you're not used to replacing this type of thing.
Thanks for this.
