Searched around a bit, but finding the latest firmware version for the colorsource AV40. Can someone point me in the right direction.
TIA
Rick
TIA
Rick
unless I'm missing something, this is not the firmware file for the console
The link Lowell posted should initiate a download of ColorSource Console v3.2.1 which is the latest. I just tested the link and this is the expected resulting file:
yes it does work and I did find this earlier... when I put all the unzip files on a usb and try to update the firmware on the board, it says no firmware files found... so Im missing something?
my understanding is the firmware file has the .fw extension...
On your USB drive are you seeing this file in the root directory (not in a folder)?
ETC_CS_Console_3.2.1.5.fw
no when it unzips none of the files have that extension...
Will you post a screenshot of what you are seeing? Are you on a Mac or PC?
working on a mac... can try on a pc instead
On Mac, it is likely auto-extracting deeper than desired so you are seeing the file bundles within the .fw file.
Please check the settings on your Mac via this Support Article: Downloading ColorSource Console Software Using macOS - Electronic Theatre Controls Inc
thank you, looking into the article now... will report back
updated successfully, thank you for your assistance!
