When I name sequences in the Playback Toy the names disappear when the console next booted up. It remembers playback memory names.
Thanks for your report. Which software version and platform (offline/console) do you see this in?
We've had a previous report of this issue, it is currently being tracked as CSCON-48240 Does not always display Sequence Name after reload of showfile.
I've added your report to the SCR.
CS20AV and latest firmware. Looks like the same issue as above but I am not sure you have to reload the show file for it to happen. I will have to check. Interesting that playback memory names are preserved.
