Just loaded a Chauvet Intimidator Spot 375ZX profile into Colorsource 40av. Everything works except I can not dim the lights with the faders only on the touch screen. I also can't turn the light off. Any suggestions.
There isn't a Chauvet "Intimidator Spot 375ZX" in library 19.1.9, only the "Intimidator Spot 375Z IRC".
Did you create a personality in the editor?
If you can attach your userlib.jlib and the fixture manual then we can take a look and hopefully find and correct the error.
