Hi There, Would you be able to create a fixture profile for the beamZ Pro IGNITE300LED Moving Head BSW as it doesnt seem to be on the most up to date fixture library.
thank you
thank you
beamz IGNITE300LED Moving Head BSW quick start guide.pdf
I found a quick start guide with the adresss parameters on it if this is enough to do a fixture profile?
This has been included in the latest Fixture Library Patch, available here: https://etcfixturescdnstorage.blob.core.windows.net/profiles/CSET_Fixture_Libraries/ETC_CS_Library_19_3_4.zip
Install by unzipping, place "ETC_CS_Library_19_3_4.cspkg" on a thumbdrive. Plug that into your ColorSource console, then navigate to Setup > Files > Advanced > Install Extras and select it.
