Is this supposed to happen?
I have a cue stack providing a slide show with associated lighting changes. There are cues in it with no image to create intentional gaps.
In these gaps I can insert some video toy effects from playback memories.
If I fade up one of these the toy comes up as expected.
Leaving the fader up I then press GO and the toy effect crossfades to the cue stack’s next ‘slide’.
So far so good. I assume the cue stack has taken over control and I can fade the toy PB out. However when I pull the playback fader down the slide from the cue stack fades out
If I then press GO with the PB fader down normal cue stack service is resumed.
If I don’t pull the fader down I can continue with the cue stack slide show until I do. The toy effect doesn’t reappear and it’s fader controls the video brightness of the cue stack images.
If there is a slide up from the cue stack when I raise the toy playback nothing happens.
Things get even more interesting if I have one toy on a playback and start to fade up another!
