The Flash button only appears when you press the "playback" button, then disappears when you select "solo".
However, this is an old bug, which still does not seem to be fixed.
CS20AV software version 3.3.0.22
In fact, this button does not work properly.
When you are lucky enough to have the touch button and press and choose "select" it displays "solo"!
So the physical buttons are sometimes lit and we don't know why!
I am desperate !!!
