When I drive a channel to 255, record it to a playback, then use that playback, it only goes to 254. What am I doing wrong?
The Playbacks master is at full.
Make sure your Grandmaster is at full too.
If you don't have a Grandmaster, then I think you've encountered a limitation of an early version of the software for some types of fixture.
This was corrected in a later version of console software.
Latest version of the console software download and install instructions are here:
https://www.etcconnect.com/Products/Consoles/ColorSource/Software.aspx
Note that there are quite a few other changes as well so wait for a suitable break in production and you'll want to have a quick look through the manual.
Firmware update fixed it. Thank you!
For humans in the future, I was at 3.1, updated to 3.3.0.25.
