Overwriting a Show File
I often have need to overwrite an existing show file using data from a different show file.  However, when I save a show file to a different show file name using the Save As method, the console will not allow me to overwrite the existing file.  i.e.  I maintain a Default file that reflects our current capabilities.  When I add a fixture to a show I would expect to be able to save that show under the Default name which would then add the fixture to our Default show file.  The console forces me to create another name to save to such as Default1.  The only work-a-round that I have found is to first delete the Default file and then perform a Save As to a new file named Default.  Is there another more sensible work-a-round to this limitation?
