How to view channel intensity? Zooming in doesn't show individual channel's intensity?
I used to be able to pinch to zoom in on the channel list/stage map and be able to view each channels current intensity but something has changed and now I am no longer able to see this characteristic. Now when I zoom in, the channel number simply gets larger. Is there a way to get back this feature or another way to view a channel's intensity?
Thank you.
  • I've taken a look in ColorSource v3.3.2 and it's working as expected there on my consoles.
    It's worth checking if your console software is up to date.
    The level appears once the icons are sufficiently large, so you may need to zoom in a little further.
    The "zoom to extents" button won't always zoom in enough for them to appear depending on your channel layout, but it can be good to touch it to reset the zoom in case you've ended up at a strange pan & zoom level.
    The level of an individual channel is also displayed on the virtual level 'wheel' when there is only one selected.
    On AV consoles channel levels are shown in the Web Remote and (when VideoToy is disabled) on the HDMI monitor.
