Hi all!
I'm about to buy a Colorsource 40 console so have a question regarding the precedence of operating areas.
As it has been mentioned in the manual, the console can only be opearated in HTP mode. So as far as I understand, if you put different effects for the common parameters (ex. X&Y) to all the playback faders and then turn them all on, then you'll get a kinda mixture on the stage. The same is valid for cues being played simultaneously with the playbacks on faders.
The question is whether is that possible to program the console in such way that when you turn off all playbacks and your cue is paused (but not stopped) the stage output would revert to that current active cue.
Thanks in advance
