I have programmed some playbacks for the fixtures ADJ PAR Z120 RGBW in 7 channel mode. [ Red, Green, Blue, White, Strobe, Dimmer, Dimmer fine]
The issue is that when we start the table, the ADJ fixture has the value of the Strobe on 8 OPEN but should be on 2 OPEN because when we move the fader it works on the intensity and the beam (strobe) parameter what is giving weird effects.
Even the playbacks have ben saved with Beam parameter Strobe = 2 open where the value does not change with the fader.
So each time we start up we need to change the parameter of the ADJ fixtures to 2 OPEN.
Is it possible that the default parameter can be changed. Is this defined in the fixture library ? Or do we look in the wrong direction....
Regards,
Philippe
ColorSource 40
Software version 3.3.3.12
Library version 20.0.4.4
