Fixture not working
Fixture not working
Have you patched "High End System SolaPix 7 Base Model"? I think that is the right one to start with.
Does it move around (Pan and Tilt) when controlled from the ColorSource 20, but does not output light?
You may have to open the Parameter controls, select "Strobe" and select "Open":
Yes I did . All other functions except intensity are working
right now I patched it as solapix 37 base module and it’s working
