I am looking for a fixture profile for the Chuavet DJ Slimpar Pro Pix
Here is the link for the manual
www.chauvetdj.com/.../SlimPAR_Pro_Pix_UM_Rev2.pdf
This fixture is available in the latest ColorSource Console Fixture Library Update : ColorSource Console v2.6 - 3.1 Library Update 18.3.3 (check for the latest version here: ColorSource Consoles)
To use it, download the library update, extract the ".cspkg" onto the root of a USB stick and then install the ".cspkg" onto your ColorSource console or EchoTouch/ElahoTouch controller using "Setup > Files > Advanced > Install Extras".
This fixture library is not compatible with ColorSource and EchoTouch software v2.5 or older; we recommend updating to v3.1.1 if you have older software.
Note that ColorSource consoles do not support multiemitter/multicell control, so the 26 and 43-channel modes are not supported.
I am very confused. I do not see it in the list nor could I find it on the console.
Hmm, it seems like something has gone wrong. I will look into it.
In the meantime, the "Chauvet SlimPAR Pro H USB 12ch" mode seems like it could control the main functions of the Pro Pix, at least to get started with.
