I have just ordered new projectors: Cameo Evos W3.
There are no lamp controls in the settings tab of each DMX mode.
I attach DMX chart.
Thanks in advance !
I attach DMX chart.
Thanks in advance !
Thank you for the report. I will see if these can be added.
My devices are on the road, they arrive tomorrow.
Can I expect a library update soon?
Otherwise, can I enter these parameters with the personality editor?
By the way, I would like to point out that the 39 and 43 channel modes do not work correctly.We are continuing to work on this request. However, I do not have a time frame for when it will be completed.
In looking at the manual, it appears that the 39-channel mode is multicell/multiemitter (it references parameters like "Green 7" - that is not directly supported in the ColorSource firmware.
I also see an issue with the 33-channel and 43-channel modes where "Dimmer" has been assigned to "Intensity 2". We will see about getting those fixed.
Thanks Matt,
I've just finish the 33ch fix.
I can send it if you want.
One more question Matt:
I tried to add all the missing lamp parameters (freq, reset, dimmer mode, etc...) via the personality editor.
Can you confirm that I can't do this this way?
Unfortunately, it is not possible for end-users to create or modify lamp commands at this time. ETC Tech Support also does not have any way of creating/modifying them - only lamp controls that are built into fixtures in the Fixture Library will work at this time.
Thanks. This would be a great improvement for a future version, and would provide better independence.
We have taken note of it.
I'm glad you realized that my last reply was bad - you can modify lamp commands, but then they become just another parameter (and don't use the Lamp Commands timing aspect)
So that means you can access them, but if they require a value to be set for a certain amount of time, you would have to execute that in a cue or by hand.
Yes, I understood that. This is an acceptable way to add missing parameters.
As mentioned in another post, the ability to choose which tab a setting would go to would be helpful.
Your right, I meant channel 33 and 43.
