- Manufacturer Name : OXO
- Model Name : ColorBeam 150
- Mode(s) needed : 7 / 11 / 35
- Link or Attachment to the Full Fixture Manual https://docs.wixstatic.com/ugd/7e664f_c854553a934e4fc280960b079d6992c4.pdf
- ColorSource version(s) required : latest
This fixture is "multi-emitter" so it cannot be controlled by a single channel of ColorSource consoles. So, we cannot make a Library profile for it.
It would need to patch a channel for its main functions and then a different channel for its White LED.
In 7-channel mode, its main functions could be controlled by Generic - IRGB 8b.
Then you would need to create a second channel for the white ring. It could be Intensity - Intensity Macros - Macros Speed. You would create it using the ColorSource Personality Editor, which you can download here: ColorSource Consoles Software
